Hey guys,
My use case is the following:
I want to monitor a certain process on Windows hosts, and show its memory usage. This process has several instances (with the same name). I can of course show the sum memory usage for all the instances using something like:
But I want to see memory usage of each instance. For this I'm guessing I need to use Zabbix low-level discovery to discover processes by PID, and create item prototypes for each discovered PID. I'll then use regex to filter just the process I want to monitor.
If this is the right solution, how would I go about doing this? or if anyone knows of an existing solution, I would love to know.
Thanks!
proc_info[process.exe,wkset,sum]
Thanks!
