pushing disabled triggers in templates
  • bloodyskullz
    • Jan 2025
    • 52
    Hi all,
    I have a template which has been already applied to a set of hosts, but i just created a new set of triggers for testing purposes but they are disabled. If I do a mass update on the hosts with the template applied, those new triggers don't appear on the host level.
    What do i need to do to have these disabled triggers appear?
    EDIT: Ignore, I figured out my carelessness!
