I'm making test for submit a shell on a Unix box when a trigger get raised ON.
If the remote command is short enough, it worked fine. And it get logged inside the zabbix_agentd.log file.
BUT if the command is too long, nothing is done nor logged !??
Is system.run limited to a max string size ?
Your issue is logged. I'm sure it will be fixed in the best possible way.
