Debugging Javascript errors in Selenium brower items
  • seren
    • Jun 2023
    • 13
    Hello all,
    I have a browser item Javascript debugging question: is there a way to see the javascript engine output, and do you have any recommendations for running/testing code outside of Zabbix?
    I ask because we have been replacing our web scenarios with Selenium browser-based checks and it's great for the most part. It's allowed us to generate 2FA/MFA tokens which was impossible with the old web scenarios (feel free to ask for the TOTP javascript code if you're interested).
    However it's been a pain to debug Javascript errors. Log statements (eg. Zabbix.log(3, "something"); ) help, but if there's a syntax error that prevents the script from running, nothing shows up in the server logs. This happens fairly frequently since the version of Javascript used by Zabbix/Selenium doesn't have some of the newer syntax and features, and thus it's easy to accidentally introduce errors that prevent anything from running.
    Does anyone know of a way to see the javascript engine output. Also, do you have any recommendations for how to test this code before throwing it into a browser item?
    Thanks!
  • Answer selected by seren at 03-12-2025, 14:31.
    troffasky
    • Jul 2008
    • 638
    Look at runtime control log_level_increase=browser poller
    • troffasky
      • Jul 2008
      • 638
      • seren
        • Jun 2023
        • 13
        Thanks! For anyone else running Zabbix in a container, this should work (you might need to change the container name):
        docker exec -ti zabbix-zabbix-server-1 sh -c "zabbix_server --runtime-control log_level_increase='browser poller'"
        docker logs -f --tail=0 -t zabbix-zabbix-server-1
        docker exec -ti zabbix-zabbix-server-1 sh -c "zabbix_server --runtime-control log_level_decrease='browser poller'"
