Monitoring disk space on virtual machines
  • theLordOfYeast
    • Nov 2016
    Hi, I'd like to monitor free disk space on my Windows Server 2012 virtual machines. VMs are set up on Windows Hyper-v Server 2012. My Zabbix version is 3.2.6.
    Hyper-v server has linked template ("Hyper-v Host") which contains discovery of all VMs - it works perfectly. Then it links template "Hyper-v Guest" to discovered machines.
    In order to find out VMs free disk space I've tried:
    1. Adding an item (key: vfs.fs.size[{C:,free]) to my "Hyper-v Guest" template
    2. Adding a discovery "Mounted filesystem discovery" which I copied from "OS Windows" template to "Hyper-v Guest" template
    3. Linking "OS Windows template" to "Hyper-v Guest" template
    In all these cases free disk space on all machines has wrong value - it's the same as Hyper-v free disk space. The only way that works is adding VMs as hosts manually (without discovery), however it's not what I'm looking for.
    If anyone has done something like this, please share a solution.
