Zabbix Grafana Integration broke after update
  • emanueldelpapa
    • Nov 2025
    My Grafana zabbix data source stopped working after updating Both zabbix and grafana, zabbix and grafana are on the same machine
    Upgrade of Zabbix or upgrade of plugin? If Zabbix upgrade, maybe you can find something from release notes, something related to authorization... but if plugin upgrade broke it, you should ask plugin support. That one ie not maintained by Zabbix...
    • emanueldelpapa
      emanueldelpapa commented
      It stopped working after the zabbix update, but i also updated the plugin and the grafana
