I am facing issue while installing zabbix server with oracle database. Please help !!!!. Using source package for installation.
Followed below link for set-up.
Oracle is DaaS service and running in different server.
zabbix-3.2.0/database/oracle/schema.sql
zabbix-3.2.0/database/oracle/images.sql
zabbix-3.2.0/database/oracle/data.sql
All Executed without errors.
2)
./configure --enable-server --with-oracle=/opa/zabixmon/oracle/product/client11gR2 --prefix=/opa/zabixmon/instance
3) etc/zabbix_server.conf
ListenPort=10051
LogFile=/opa/zabixmon/instance/zabbix/logs/zabbix_server.log
LogFileSize=10 #in mb; need to see how verbose this log gets
DebugLevel=3 #warning level
PidFile=/opa/zabixmon/instance/zabbix/logs/zabbix_server.pid
DBHost=hkxxx-scan.hk.standardchartered.com
DBName=DEV.hk.standardchartered.com
DBUser=DEV_21
DBPassword=DEV_21_123
DBPort=1622
4) startup issue
cd /opa/zabixmon/instance/sbin/
./zabbix_server
Error :
38492:20170714:214327.790 Starting Zabbix Server. Zabbix 3.2.0 (revision 62485).
38492:20170714:214327.791 ****** Enabled features ******
38492:20170714:214327.791 SNMP monitoring: NO
38492:20170714:214327.791 IPMI monitoring: NO
38492:20170714:214327.791 Web monitoring: NO
38492:20170714:214327.791 VMware monitoring: NO
38492:20170714:214327.791 SMTP authentication: NO
38492:20170714:214327.791 Jabber notifications: NO
38492:20170714:214327.791 Ez Texting notifications: NO
38492:20170714:214327.791 ODBC: NO
38492:20170714:214327.791 SSH2 support: NO
38492:20170714:214327.791 IPv6 support: NO
38492:20170714:214327.791 TLS support: NO
38492:20170714:214327.791 ******************************
38492:20170714:214327.791 using configuration file: /opa/zabixmon/instance/etc/zabbix_server.conf
38492:20170714:214327.979 cannot use database "DEV.hk.standardchartered.com": Zabbix server cannot work with a Zabbix proxy database
2)
ListenPort=10051
DBUser=DEV_21
DBPort=1622
4) startup issue
./zabbix_server
Error :
