Active Directory / LDAP
  • itadmin@jandoplastics.com
    • Dec 2025
    Im trying to setupAD / LDAP with Just in Time
    I can get the LDAP server to connect, test and login from the web interface.
    Enabled JIT on the LDAP settings form and on the LDAP server form.
    I am using the Base DN of the domain
    group configuration is memberOf
    ldap group pattern is set to my AD security group and set to in thi case super admin role.
    I run a test and the test seems to be successful but I see nothing in the User role or user groups.
    When I try to login as the AD user account I get a login failure.
    Not sure what I am missing here.
    No spaces - or . in the username.
    Not sure what im missing, I swear I had this same issue in 7.2 a while back.
  • zabbixuser39393
    • Jan 2021
    • 38
    What distribution of Linux?
      [email protected] commented
      sorry I did not see this earlier.
      Ill check but dont think anything in Linux is needed unless some firewall is blocking the necessary AD ports
  • Manuel Deschambault
    • Jan 2026
    • 18
    I don`t think the distro of Linux under the hood matters much. I setup JIT with our Active Directory and did not require anything in the OS, all of the setup was done in the Zabbix GUI.
      • Dec 2025
      Interesting would yu mind sharing what you did to set it up ?
      For some reason I just can get it to communicate.
