which client to use on Xenserver 8.4?
  • jony1002
    • Dec 2025
    I have a number of these hosts and have tried all the (reasonable) combinations of linux version and distribution but can't find a zabbix client that will install.
    # cat /etc/redhat-release
    XenServer release 8.4.0 (xenenterprise)
    All attempts give some version of this:
    # yum install zabbix-agent2
    --> Running transaction check
    ---> Package zabbix-agent2.x86_64 0:7.4.5-release2.el8 will be installed
    --> Processing Dependency: libcrypto.so.1.1(OPENSSL_1_1_0)(64bit) for package: zabbix-agent2-7.4.5-release2.el8.x86_64
    --> Processing Dependency: libssl.so.1.1(OPENSSL_1_1_0)(64bit) for package: zabbix-agent2-7.4.5-release2.el8.x86_64
    --> Processing Dependency: libssl.so.1.1(OPENSSL_1_1_1)(64bit) for package: zabbix-agent2-7.4.5-release2.el8.x86_64
    --> Processing Dependency: libc.so.6(GLIBC_2.28)(64bit) for package: zabbix-agent2-7.4.5-release2.el8.x86_64
    --> Processing Dependency: libcrypto.so.1.1()(64bit) for package: zabbix-agent2-7.4.5-release2.el8.x86_64
    --> Processing Dependency: libpcre2-8.so.0()(64bit) for package: zabbix-agent2-7.4.5-release2.el8.x86_64
    --> Processing Dependency: libssl.so.1.1()(64bit) for package: zabbix-agent2-7.4.5-release2.el8.x86_64
    --> Finished Dependency Resolution
    Error: Package: zabbix-agent2-7.4.5-release2.el8.x86_64 (zabbix)
    Requires: libssl.so.1.1()(64bit)
    Requires: libssl.so.1.1(OPENSSL_1_1_1)(64bit)
    Requires: libssl.so.1.1(OPENSSL_1_1_0)(64bit)
    Requires: libcrypto.so.1.1(OPENSSL_1_1_0)(64bit)
    Requires: libcrypto.so.1.1()(64bit)
    Requires: libpcre2-8.so.0()(64bit)
    Requires: libc.so.6(GLIBC_2.28)(64bit)
    You could try using --skip-broken to work around the problem
    You could try running: rpm -Va --nofiles --nodigest
    I can get reasonable data just using SNMP but having the zb client on there would be better.​
    It clearly lists required things. Try to resolve those issues first..
