Azure by HTTP - customising names of discovered resources
  • DaveFO
    • Dec 2025
    Hi all,
    I am experimenting with the Azure by HTTP template. I have added the template to a new host and it discovers everything as expected which is great. the only problem is we monitor multiple Azure tenancies and Subscriptions. Is it possibly to prepend the discovered resources with a specific macro name? Basically when we add a host to do the discovery it would be great if we could say specify a macro that will prepend discovered resources with that name rather than "Azure virtual machine" or "Azure vault"
    Dave
    You can experiment with host level user macros and edit template to use it... For multiple tenancies and subscriptions you need to specify those on host level anyway.
