Template help to read host json files?
  • G0nz0uk
    • Apr 2021
    • 72
    I'm still learning how to use Zabbix and quickly finding out how powerful it is. I've managed to created my own SNMP template to monitor a few hundred hosts/devices. These devices also have a json file attached to them on something like:
    Not all hosts have this URL but eventually they all will and I need to alert on information in that json file should we hit a threshold.
    Now I'm a bit lost on this next bit.
    So I've already learnt on how scrape/discovery a json file if it's a large json file dump and pick out what date I need from that. I've done this for another json output I needed Zabbix to read, but this is 1 large json file containing devices/host names and metrics, I used a LLD and Macros and all works nicely.
    This time I need to do the same or similar thing, but for each host/device instead and read their individual json file.
    Do I create a new template and add this as a second template for each host/device to use so they will have an SNMP template and this JSON template I need to create one or is there a better way? I wanted if I can run the SNMP discovery and link this new discovery or template after?
    Also on the discovery I'd need to point to the devices IP address on the url, what would the variable look like to insert the IP URL to scrape/discover?
    https://{HOST.IP}/agent/metrics.json
    Apologies if I've not explained that properly. If I've missed anything off please let me know.
  • Answer selected by G0nz0uk at 22-01-2026, 11:59.
    irontmp
    • Sep 2023
    • 87
    Do I create a new template and add this as a second template for each host/device to use so they will have an SNMP template and this JSON template I need to create one, or is there a better way? Similar to how seo services for architects optimize multiple aspects of a site, you can keep SNMP and JSON templates separate for clarity and efficiency. I wanted to know if I can run the SNMP discovery and link this new discovery or template after?
    You should create a separate JSON template and link it to each host alongside your SNMP template. Use {HOST.IP} in the URL like https://{HOST.IP}/agent/metrics.json so Zabbix fetches the JSON from the correct host. Then use LLD or dependent items within that template to parse the metrics and trigger alerts. SNMP discovery and JSON discovery can run independently on the same host; there’s no need to combine them.
      • 4961
      I would keep different things in different tempaltes... If nothing else, at least it makes testing easier, if you can only apply it to some hosts instead of all..
      {HOST:IP} is the one pointing to hosts registered IP (first agent interface, if that is missing, then SNMP, then JMX, then IPMI, then *unknown*)
      • G0nz0uk
        • Apr 2021
        • 72
        I’ll keep as separate. The thing is not all devices will have the info I need that the 2nd template will try and get. Over time they will though.
        if assign to all and it can’t get that info will it just quickly skip and then try the next host anyway?
        thanks
          • 4961
          If you attach a template, which tries to read nonexistent file, you get a "not supprted" item there and It will try again time to time... you can have items disabled in template and only enable those on hosts, where you know this file to be present...
          • G0nz0uk
            • Apr 2021
            • 72
            Is it {HOST:IP} or {HOST.IP} ?
            I'd like to use that name to show in the trigger alerts too and I assume this will be {HOST.NAME}
            • irontmp
              • Sep 2023
              • 87
              • G0nz0uk
                • Apr 2021
                • 72
                Thanks, I eventually got there with what you mentioned above last week, it's so clever!
