Never had an issue with update from the repository, these are well maintained servers with all the latest updates.
dnf shows current installed version is 6.0.42-release1.el8
Seeing across all our servers (OEL8). dnf clean did not resolve, nor did I anticipate it would.
I see nothing in release notes indicating a repository key change in 6.0.43. The key referenced matches the (2016 dated) key in the repo.
We are very security conscious and our perception is the 6.0.43 package was not properly signed, corrupt or not genuine.
Wondering if others can shed light on this.
$ sudo dnf update
This system is receiving updates from Unbreakable Linux Network or Spacewalk.
Last metadata expiration check: 0:27:21 ago on Wed 17 Dec 2025 10:54:49 AM EST.
Dependencies resolved.
Package Architecture Version Repository Size
Upgrading:
zabbix-agent x86_64 6.0.43-release1.el8 zabbix 588 k
Transaction Summary
Upgrade 1 Package
Total download size: 588 k
Is this ok [y/N]: y
Downloading Packages:
zabbix-agent-6.0.43-release1.el8.x86_64.rpm 833 kB/s | 588 kB 00:00
Total 829 kB/s | 588 kB 00:00
Zabbix Official Repository - x86_64 1.6 MB/s | 1.7 kB 00:00
GPG key at file:///etc/pki/rpm-gpg/RPM-GPG-KEY-ZABBIX-A14FE591 (0xA14FE591) is already installed
The GPG keys listed for the "Zabbix Official Repository - x86_64" repository are already installed but they are not correct for this package.
Check that the correct key URLs are configured for this repository.. Failing package is: zabbix-agent-6.0.43-release1.el8.x86_64
GPG Keys are configured as: file:///etc/pki/rpm-gpg/RPM-GPG-KEY-ZABBIX-A14FE591
The downloaded packages were saved in cache until the next successful transaction.
You can remove cached packages by executing 'dnf clean packages'.
Error: GPG check FAILED
$ sudo dnf update
Upgrading:
Transaction Summary
Upgrade 1 Package
Is this ok [y/N]: y
