php-fpm monitoring
  • spyro
    • Dec 2025
    php-fpm monitoring
    Hi all,
    I've been banging my head in this one for a while now. How do you get zabbix 8 to auto discover PHP-fpm pools?
    I've configured unique URLs for the pool status reporting, and the first pool works fine (/status and /ping). I can't for the life of me seem to figure out how to configure zabbix to locate the other pool (/status2 and /ping2)
    I'm sure its something to do with discovery, but the whole discovery process is weird and opaque to me. I'm sure it's something to do with the PHP-FPM template, but I can't figure out how it's supposed to work.
  • Viktors Fomics
    • Oct 2025
    • 52
    Hello
    Indeed the PHP-FPM template is designed to work with a single pool, therefore to monitor the second pool you will need either a separate host or a separate LLD rule within the same host, with the PHP-FPM status macro set to the one corresponding to that pool.
    • spyro
      • Dec 2025
      Any chance you could expand on how to do this? I'm new to zabbix.
      • emb
        • Aug 2026
        Hello
        I'm interested in monitoring php-fpm different pools on my server. Did you manage to get it working?
        Thanks in advance!
