Zabbix Agent & Template Compatibility for HP-UX 11.31
  • Changs
    • Jun 2025
    I would like to ask for clarification regarding the Zabbix template compatibility for HP-UX 11.31 (RISC).
    Currently, our monitoring environment is running on Zabbix Server version 7.4.
    Based on our review, it appears that the HP-UX Zabbix templates are compatible with Zabbix 6.0 or later. However, when checking the actual Zabbix Agent installation files available for HP-UX 11.31 (RISC), we were unable to find any agent packages corresponding to Zabbix Agent version 6.0 or higher.
    Could you please confirm:
    1. Which Zabbix Agent version is officially supported for HP-UX 11.31 (RISC)?
    2. Whether the 6.0+ templates are intended to be used with older agent versions on HP-UX in a Zabbix 7.4 server environment, or
    3. If there is an alternative or recommended template specifically for environments where only older agent versions are available.
    Your guidance would be appreciated so we can ensure proper compatibility and stable monitoring.
    Thank you.
  • troffasky
    • Jul 2008
    • 639
    The agent protocol either hasn't changed, or is compatible enough, that server 7.4 can talk to older agents without difficulty [I have had it working with agents running 3.x].
    What will not work, is items that were added in Zabbix after the version of the agent you are using [it's not clear what version you are using, <6.0? But doesn't really matter, answer is the same].
    • Changs
      Changs commented
      We will proceed with the agent installation and testing.
      Thank you very much for your support.​
  • guntis_liepins
    • Oct 2025
    • 61
    Zabbix does not build HP-UX packages anymore, but you may compile zabbix agent from sources and ask for assistance here in case of problems.
    It may work as zabbix have Official HPUX template HP-UX monitoring and integration with Zabbix and in page it is mentioned that it require Zabbix agent version 7.4 .
    Don't have any HP-UX around to help you more unfortunately
    • Changs
      Changs commented
      We’ll install the agent and run some tests.
      Thank you for the clarification.
