zabbix problem automatically resolved in 1 minutes
  • sisirtiwari
    • Jul 2017
    I dont know what's going on with my zabbix. I can see a problem status in dashboard but it get resolved automatically after 1 minute though it is in problem.
  • batchenr
    • Sep 2016
    • 440
    does the issue the dashboard shows is real or false positive ?
    what is this trigger about ?
    please add more details
    • sisirtiwari
      • Jul 2017
      I have a default trigger for p2p connection between routers.
      trigger expression is {hostname:ifOperStatus[port25].diff(0)}=1 for port 25.
      The trigger is active when problem occurs but didn't lasts more than a minute even though the device is still in problem state.
      • tasbirnitole
        • Sep 2015
        • 12
        Was your problem solved? I am facing the same issue for some of my devices.
        • Markku
          • Sep 2018
          • 1784
          Hi, diff()=1 triggers when the value changes. When the next value is collected (in one minute if the item interval is 1m), the trigger is evaluated again. If the new value is the same as previous value, then the diff() is zero, and the problem event is cleared.
          Thus, a trigger based on plain diff() is not suitable if you want to sustain the problem status over longer period of time.
          Markku
