HI, we want to connect zabbix to our ITSM tools. I can see two methods.
Using alert script (script is run by server)
Using remote command (script is run by agent).
I wonder what is the recommanded method or there is no difference?
What I saw:
-- Remote command --
no timeout cause using system.run(,nowait)
no indication on remote command status result
-- Alert script --
Timeout max = 30s
Status result
Any other limitation or restriction that could make the difference?
Regards,
Marc
What I saw:
-- Alert script --
Timeout max = 30s
Status result
Regards,
Marc
