Please help. My Zabbix and Firewall has been running but when I look at the graph, it has breaks. I have no idea why.
Breaks in Graph
what does this graph update interval ?
if its 5 min then you will see this cuts
and if its network connection error you will see more info in zabbix server log -
there is an item that get the graph data
Configuration->host-> under the host you will see Graphs
and there press on the graph you want and u will see its item.
and then go to items and see what is its update intervslComment
What is a graph of items?
Are you using the default SNMP template?
If it is the default template, I think you are using IF-MIB::ifInOctets and IF-MIB::ifOutOctets.
Even if it is not a default template, caution is required when using these OIDs.
The counter for this OID is a 32bit counter.
If you use high-speed network, that counter can easily overflow and obtain values only in discrete fashion.
Also, if you are using IF-MIB::ifInOctets and IF-MIB::ifOutOctets, let's try using IF-MIB::ifHCInOutets and IF-MIB::ifHCOutOctets.
If you are not using 32bit counter, please try to disable bulk requests.
Turn off the check box in the host's SNMP interface settings.Comment
