CVE-2025-14847
  • mouchyn
    • Apr 2021
    • 10
    CVE-2025-14847
    Our IT Security team says all of our zabbix-agent2 instances are vulnerable to CVE-2025-14847. Can anyone positively confirm or deny that? Should we assign resources to patch all deployed zabbix agents outside of our normal patch cycle?
    Thanks!
  • PavelZ
    • Dec 2024
    • 171
    Do you usually install the package zabbix-agent2-plugin-mongodb plugin?
    Try uninstalling it and asking them again.
    • mouchyn
      • Apr 2021
      • 10
      Yep, that was it. Thanks! All of our RHEL systems have this installed, presumably because of zabbix agent defaults:
      # yum list installed | grep zabbix
      zabbix-agent2.x86_64 7.0.22-release1.el9 zabbix
      zabbix-agent2-plugin-mongodb.x86_64 7.0.22-release1.el9 zabbix
      zabbix-agent2-plugin-mssql.x86_64 7.0.22-release1.el9 zabbix
      zabbix-agent2-plugin-postgresql.x86_64 7.0.22-release1.el9 zabbix
      zabbix-get.x86_64 7.0.22-release1.el9 zabbix
      zabbix-release.noarch 7.0-5.el9 zabbix
      zabbix-sender.x86_64 7.0.22-release1.el9 zabbix
      They used the fleet inventory system to query for installed software that includes "mongodb" and NOT $known-good-version-number. I pointed out how the report is a false positive and we're all good.
