Monitoring Proxmox Cluster with Agent2, getting duplicate data
  • Dasani_Bottled
    • Jan 2026
    I currently have a Proxmox Cluster with 3 nodes, Ive installed an agent onto my primary node in the cluster and im getting data from all three nodes instead of just one. Its making it hard to create maps and track my devices properly, is this an issue that any one else is facing or is this the intended functionality?
  • irontmp
    • Sep 2023
    • 98
    Originally posted by Dasani_Bottled
    I currently have a Proxmox Cluster with 3 nodes, I’ve installed an agent onto my primary node in the cluster and I’m getting data from all three nodes instead of just one. It’s making it hard to create maps and track my devices properly, and I plan to troubleshoot this later. Is this an issue that anyone else is facing or is this the intended functionality?
    This is expected behavior. Installing the agent on the primary Proxmox node usually collects data from the entire cluster, which is why you’re seeing all three nodes. To track a single node, you need to either install the agent only on that specific node or adjust the agent settings to limit its scope to just the local host.
    • troffasky
      • Jul 2008
      • 639
      I think that's what the OPs question is.
