How enable x-forwarded-for / client ip instead of load balancer ip at logging?
  • zabbixuser39393
    • Jan 2021
    • 38
    We connect to Zabbix UI (two sites) via loadbalancer. How I change Zabbix user logging data configuration so, that logged ip is actually real client ip, not load balancer ip. Load balancer sends x-forwared-for info.
    -Apache 2.4
    -Zabbix 7.0
    Not really a zabbix question ...
    First couple of Google results
    There’s been a lot of debate here in the office about how best to capture both your Loadbalancer’s IP and the Source IP of the user in your access_log in Apache 2.4. This is the tried and tested method we've come up with.
    https://serverfault.com/questions/88...for-is-present
    • zabbixuser39393
      • Jan 2021
      • 38
      Well, why not if it Zabbix audit log shows always incoming traffic source ip? Traffic is always coming from load balancers ip and logging to audit log "user" "loadbalancer ip" and we want log "user" "X-Forwarder-for IP address"? We are not looking or logging httpd access log. Instead we look incoming web trafic and want to pick up (like) X-Forwarder-for:10.1.1.1 value to log.
      • zabbixuser39393
        • Jan 2021
        • 38
        Thx Cyber for that link. Now Apache log contains client ip. But no changes at Zabbix ui audit log
          Zabbix own audit log is different matter. I did not even consider it, when answering.. I have no idea, how that can be changed.. Might be a question to support...
          But apache config is universal, whatever aplication it serves. Thats why "it is not zabbix question"..
          • irontmp
            • Sep 2023
            • 98
            Originally posted by zabbixuser39393
            Well, why not if it Zabbix audit log shows always incoming traffic source ip? Traffic is always coming from load balancers IP and logging to audit log 'user' 'loadbalancer ip' and we want log 'user' 'X-Forwarder-for IP address'; kind of like how a Minecraft Mod picks up custom data in the game. We are not looking or logging httpd access log. Instead we look at incoming web traffic and want to pick up (like) X-Forwarded-For:10.1.1.1 value to log.
            Enable Apache’s mod_remoteip and configure it to use the X-Forwarded-For header from your load balancer. Set your load balancer’s IP as trusted with RemoteIPTrustedProxy. After restarting Apache, Zabbix will log the real client IP instead of the load balancer IP.
            • zabbixuser39393
              zabbixuser39393 commented
              Maybe in perfect world, but not at our envinronment. I can get writing xff ip to log, but real ip shall not go through apache (and does not affect %a real ip as apache log) to zabbix. And I think that we have tried every apache configurations. It looks like that php / zabbix does not get xff ip. Bug in apache Server version: Apache/2.4.62 (Red Hat Enterprise Linux) or Zabbix?
              edit: We can see X-Forwarded-For:[IP] at forensic logs at virtual server log. Apache or Zabbix (7.0.22) just not catch that ip.
          • zabbixuser39393
            • Jan 2021
            • 38
            irontmp was close - our configuration is:
            RemoteIPHeader X-Forwarded-For
            RemoteIPInternalProxy [ip] (only one address for lb)
            Most confusing setting was at Zabbix Reports - Audit log page Right Up Cornep Filter setting. There was load balancer ip as filter and then client ip doesn't updated to audit log.
            And Yes. It was Apache, not Zabbix configuration.
