Some personalized widget?
  • Odelh39
    • Jan 2026
    I'm new to zabbix's world.
    Some years ago I had used EyesofNetwork which offered a thruk widget : mine map.
    Could you tell me if it would be possible to use, adapt or create some zabbix widget to get something looking like that?
    the goal is to select a host group. For this one, it shows hosts in first column and for each host it shows the status of some wanted elements/triggers.
    what is useful for me is the fact that adding a host in the group inserts it automatically in the list
    Thanks a lot for your help and ideas
    Zabbix allows additional custom frontend modules.. https://www.zabbix.com/documentation.../devel/modules
    So "creating" is possible... but you need to do it probably by yourself..
    • kyus
      • Feb 2024
      • 203
      Have you tried the "Top hosts" widget? It's not exactly what you described, but it allows the selection of a host group (so it gets populated automatically) and it'll display the items that you configure in each column.
      Maybe this can help you in some way.
      • Odelh39
        Odelh39 commented
        thanks, I tried it but it's not what I want
        thanks
    • Odelh39
      • Jan 2026
      I tried to create the widget (with a little help from AI but it's not at the top for that)
      I get some errors
      Could I send the code, or files here (or somewhere else) to get a help ?
