Problem getting a negative calculated value
  • Manuel Deschambault
    • Jan 2026
    • 27
    I want to keep an eye on 3 Kafka folders (web processing). Here is what I have done:
    1. Mounted the kafka folders as "read-only" on my LinuxHelper VM
    2. Written an SNMP extension returning the values of the number of items in the 3 folders as a string in the format x;y;x
    3. Created an SNMP item in Zabbix receiving this string and being polled every minute
    4. Created 3 "Dependent item" items, that extract the proper number from the string (using Preprocessing) as saving it as a "Numeric (float)"
      1. For each of the 3 items, created the two following items (since change items do not keep negative values):
        1. A calculated item (call it last2), showing the 2nd to last value saved as "Numeric (float)"
        2. A calculated item (call it last), showing the last value saved as "Numeric (float)"
    All the above steps work fine, here is where I am stuck and can't seem to find the fix
    I then created another calculated item (call it "Change" set to: last(//Last2) - last(//Last), saved as "Numeric (float)"
    Over the normal operation, the count of kafka files varies, and if the karka count goes from 50 to 30, I do see:
    1. Last2=50
    2. Last=30
    3. The "Change" calculated items should be -20
    But the last calculated item "Change", refuses to show any negative numbers, the graph from the "last values" section only shows positive values, with 0 where values would be negative
    Having negative values for my kafka change folder is critical for me to create a good alert to show a stuck web process where kafka files are no longer processed, i.e. if no negative value in past 30 minutes, send alert
  • kyus
    • Feb 2024
    • 210
    If everything is set correctly you should be seeing negative values. And some things that might help you, since you pointed these things:
    In fact, change items do keep negative values, and I strongly suggest you use change(//itemkey) instead (more on this later).
    You don't really need calculated items to store the previous values of your item. You can always refer to the 2nd to last value using "last(//itemkey,#2)". So your item could be last(//itemkey,#2)-last(//itemkey)
    With that said, I don't recommend it because if you were to have negative values coming from your item (probably not your case), the calculation would get messed up.
    So, I think you should try using the change function directly with your "main" item, without creating those calculated items to store previous values.
      • Jan 2026
      • 27
      I found the issue... I had initially chosen the wrong numerical type "Numerical (unsigned)", and even though I had toggled them all to "Numerical (float)", I would not get negative values.
      I deleted all the items and recreated them with the proper value from the get go, everything works now.
      Mental note, creating an item with "Numerical (unsigned)" and updating it to "Numerical (float)", does not work, you do not get negative values.
      Thanks for the help.
      • troffasky
        • Jul 2008
        • 640
        If that is the case then it is specific to negative/not-negative. Many, many times I have created items with the wrong type first time around, corrected it and then the data is stored correctly.
          • Jan 2026
          • 27
          Just an update, everything is working fine, and just got an alert for a legitimate failure where a stuck kafka process was identified.
          • irontmp
            • Sep 2023
            • 99
            1. Last2=50
            2. Last=30
            Having negative values for my kafka change folder is critical for me to create a good alert to show a stuck web process where kafka files are no longer processed, and similar to testing with a firearm training simulator, if no negative value appears in the past 30 minutes, an alert should be sent.
            The issue is that your “Change” calculated item is likely treated as unsigned, so negative values are not stored. To fix this, ensure the “Change” item is set to Type: Numeric (float) and Unsigned is not checked. Once it allows signed numbers, last(//Last2) - last(//Last) will correctly produce negative values, and your graphs and alerts will reflect decreases in Kafka file counts.
