Help with Zabbix API
  • Bercko21
    • Dec 2015
    I'm trying to use a script to add hosts to pre-created maintenance.
    I don't have anby expirience working with API and JSON and this is my first try.
    I have a script that logged in, get the authentication token and create the maintenance and get it's ID.
    Afterward, I'm trying to add hosts to the maintenance using this command:
    curl -s -X POST -H 'Content-Type: application/json-rpc' -d '
    "jsonrpc": "2.0",
    "method": "maintenance.update",
    "params": {
    "maintenanceid": "40",
    "hostids": [
    "10108",
    "10114"
    "auth": "b760203158f58ae193241fddec63cc5e",
    "id": 1
    ' http://$zabbixserver/zabbix/api_jsonrpc.php
    The JSON in straight from the API manual (https://www.zabbix.com/documentation...tenance/update)
    After execution, I'm getting the following error:
    "id": 1,
    "error": {
    "data": "\"Active since\" must be between 1970.01.01 and 2038.01.18.",
    "message": "Invalid params.",
    "code": -32602
    "jsonrpc": "2.0"
    Any idea how to solve it?
    Thanks!
