Feature to select different proxy for interface in Host config
  • r0k
    • May 2020
    is there a way to monitor a single Host via different proxies.
    Example:
    Monitor HostA:
    Agent: no proxy
    IPMI: proxyA
    I assume most people have IPMI at least on a different VLAN.
    Currently I only see two options.
    Have two Host configurations, one for Agent and one for IPMI.
    Have a mutlihomed proxy in both networks for Agent and IPMI.
    Cheers,
    Oliver
  • BP_Vital
    • Feb 2016
    • 50
    Hello, there is indeed feature request for your case:
    At least you're not the first bumped into that
      • 4985
      Created: 2012 Sep 07 12:47
      Updated: 2018 Feb 16 13:04
      Does not seem to be a popular one...
      • troffasky
        • Jul 2008
        • 638
        Your description of the scenario reads like nothing has a route out of its local network.
        • r0k
          • May 2020
          Thanks. Hard to believe that people have either a flat network structure or they create multiple host entries for the same machine...
          • troffasky
            • Jul 2008
            • 638
            I think I see what you mean now. Yes, we treat [for example] a Proxmox host and the iDRAC card for that host, as separate hosts in Zabbix. It was the talk of proxies that threw me off the scent.
