Monitor memory for specific windows process
  • advanm
    • Dec 2012
    • 9
    I'm just started with zabbix upgraded from 1.8 to 3.2. How can i monitor the memory usage of a specific windows process.
    i googled for this but didn't found the right solution for this.
  • sancho
    • Mar 2015
    • 301
    Hi advanm,
    You can use the proc_info item, for example, for the java process I have it as follows:
    Key: proc_info [java.exe,wkset,sum]
    Type: Numeric (Float)
    Units: Gb
    Use custom multiplier: 0.000001
    I hope it helps you.
    • riekeltkeuter
      riekeltkeuter commented
      Thank you, this is very helpfull.
      In order to convert Bytes to Gigabytes, i used multiplier "0.00000095367431640625" instead of 0.000001
  • ysus
    • Mar 2016
    • 103
    The proc_info item does not provide full information about specific process, for example you could not monitor "Non-Paged Pool" to check if there is memory leak.
    1. Download free utility from here https://docs.microsoft.com/en-us/sys...wnloads/pslist and copy it to C:\zabbix
    2. Add new UserParameter=someprocess,"C:\zabbix\someprocess.c md" to zabbix config file on client
    3. Edit someprocess.cmd
    @echo off
    SET result=
    FOR /f "tokens=8" %%I IN ('C:\zabbix\pslist.exe -accepteula -m -e yourprocessname 2^>^&1 ^| more +8') DO SET result=%%I
    IF [%RESULT%] EQU [] (echo 0) ELSE (echo %RESULT%)
    4. Add new someprocess item to zabbix server
    • sancho
      • Mar 2015
      • 301
      I did not know this option,
      Thanks for the information
