Honeycomb widget settings
  • ZabbTore
    • Feb 2026
    I wish it were possible to set a filter in, for example, the Honeycomb widget, so that the green ones are not shown.
    Is there a way to only show those with severity status High and Disaster?
    Zabbix 7.4.6
  • bbonno
    • Apr 2025
    • 24
    This can be shoehorned in with clever use of tags that you can filter by.
    This does require that your items come from a discovery process that can set the tags you need. Note that setting the item value in the tag does not work very well, as the filters don't support Greater/Less than.
