Why cannot show container info on my host
  • bab
    • Aug 2020
    • 197
    I got follow error on my item :
    Cannot fetch data: Get "http://1.28/containers/json?all=true": dial unix /var/run/docker.sock: connect: permission denied.
    Also it has follow permission for the path :
    ll /var/run/docker.sock
    lrwxrwxrwx. 1 root root 23 Nov 12  2024 /var/run/docker.sock -> /run/podman/podman.sock
    Also docker user does not exist
    usermod -aG docker zabbix
    usermod: group 'docker' does not exist
  • troffasky
    • Jul 2008
    • 639
    Because Podman is not Docker.
    • bab
      • Aug 2020
      • 197
      Originally posted by troffasky
      Thanks but please follow info :
      [root@e ~]# cat /etc/passwd | grep -i podman
      [root@e ~]# cat /etc/passwd | grep -i docker
      [root@e~]# systemctl status podman.service
      ● podman.service - Podman API Service
         Loaded: loaded (/usr/lib/systemd/system/podman.service; disabled; vendor preset: disabled)
         Active: inactive (dead)
           Docs: man:podman-system-service(1)
      As you can see there is no podman and docker user and podman service is stopped on the other hand my container is running .
      [root@e ~]# ll /run/docker.sock
      lrwxrwxrwx. 1 root root 23 Nov 12 2024 /run/docker.sock -> /run/podman/podman.sock
      docker ps
      Emulate Docker CLI using podman. Create /etc/containers/nodocker to quiet msg.
      CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
      f600219f72c4 docker.io/mysql/mysql-server:latest mysqld 15 months ago Up 15 months (healthy) 0.0.0.0:3306->3306/tcp mysql_server​
      • troffasky
        • Jul 2008
        • 639
        I thought your question was about monitoring Podman from Zabbix with Docker monitoring template. But now I am not actually sure what your question is.
        • bab
          • Aug 2020
          • 197
          I am really confused both commands are working on my redhat OS:
          [root@e ~]# docker ps
          [root@e ~]# podman ps
          [root@e ~]# systemctl status podman.service
          Cannot fetch data: Get "http://1.28/info": dial unix /var/run/docker.sock: connect: permission denied.
            Agent runs as user "zabbix", it most probably has no access to default docker (podman) socket...
            Your docker.sock seems to be a link to podman.sock, But that might have different access rights...
