Host Interface and Item host interface - Client not running an agent or snmp?
  • furicle
    • Feb 2026
    New Zabbix user - I'm sure this is me-issue :-)
    Running Zabbix 7.4.7 on Alma Linux 9 (bare metal)
    I've set up a number of machines to monitor successfully using the agent 2.
    Now I'd like to add a series of old print servers. They expose ports tcp 80, 515, and 9100. No SNMP available.
    Started by Data Collection → Hosts -→ Create Host
    I don't see a template for this kind of thing, so I'm leaving that blank.
    I don't know what to put under Interfaces... the end machine is not running an agent, SNMP or IPMI ? I have tried both using 'Agent' and leaving this undefined. I suspect this is my issue...
    Then went to Items for the host created above
    Tried to set up two simple checks with keys of
    net.tcp.service[tcp,,9100]
    and
    net.tcp.service[tcp,,515]
    Here I don't know what to use for 'Host Interface' - I have tried leaving it blank, and choosing the agent if I set up the host as 'agent'
    These checks always return zero as far as I can see.
    I have confirmed ports are open, with both nmap and by running
    nc -zv target.example.com 9100
    and the printer is actually in use :-)
    So I have two questions...
    1 - how do I set up a host that I want to add simple checks to? or
    2 - can I put two or three simple checks together into a template? So when I add another printer later, I can pick that template and it will apply the same two or three simple checks?
  • Answer selected by furicle at 23-02-2026, 23:44.
    troffasky
    • Jul 2008
    • 639
    Create an agent interface [even though you can't use the agent] with the IP or hostname of the printer.
    Yes, you can [and should] create a template with the items you want to poll from multiple hosts.
    • furicle
      furicle commented
      Thanks for confirming that.
      I have realized since part of my issue was that host names are case sensitive - and the hosts in question weren't consistently cased... i.e. I had some hostA.example.com and hostb.example.com
      Now I guess I'm off to research setting up templates :-)
  • troffasky
    • Jul 2008
    • 639
    • furicle
      furicle commented
