Web ui Media type Message templates text view problem
  • zabbixuser39393
    • Jan 2021
    • 38
    Look at picture... What can cause this and how to fix it?
    Also Problems view does not have "colours"
  • zabbixuser39393
    • Jan 2021
    • 38
    More info RHEL 9 / Apache 2.4.62-7.el9_7.3 / php 8.2.30-1.module+el9.7.0+23849+7b831f17
    Every else "boxes" except this Media type - Message template are shown ok. Only this one does cut view and does not fit to visible view.
    Any suggestions how to resolve this?
    • guntis_liepins
      • Oct 2025
      • 61
      well I do not see any problem here. Please explain.
      If timeline bothers you , just deselect "Show timeline" in Problem View.
      • zabbixuser39393
        • Jan 2021
        • 38
        Case solved. I had something writed wrong with httpd .conf file ( this was added to zabbix.conf). Commenting out these two line and Ui works "normally".
        Header set Strict-Transport-Security "max-age=31536000"
        Header set Content-Security-Policy "default-src 'self' *.openstreetmap.org; script-src 'self' 'unsafe-inline' 'unsafe-eval'; connect-src 'self'; img-src 'self' *.openstreetmap.org data:;"
          • 4993
          First header set is for HSTS, which should not interfere with any page content.. its just a security measure, forcing to use https.
          I suppose other one is something fo embedding openstreetmaps data ...
