Add host in hostgroup by hostname
  • sbartesaghi
    • Feb 2026
    Hi All,
    I'm a new on zabbix and I install Zabbix 7.4, I create all my discovery rules with SNMPv3 checks; I create the rules like this:
    Discovery1: 192.168.1.0/24, 192.168.2.0/24 etc
    Where Site 1 is 192.168.1.0/24 and site 2 is 192.168.2.0/24
    Then I import the host with general discovery action
    is there a possibility to add the host in a specific hostgroup by regex on his hostname and link specific template?
    Example: -
    Host: SITE1SW100A --> Add to hostgroup Site-1 and Link Template: Switch, Ping
    Host: AP1_50 --> Add to hostgroup Site-1 and Link Template: AP, Ping
    Host: AP2_50 --> Add to hostgroup Site-2 and Link Template: AP, Ping
    Host: SITE2SW100A --> Add to hostgroup Site-2 and Link Template: Switch, Ping
    I try to do it with autoregistration rule but it works only with zabbix Agent, instead I want process the hostname that I set on zabbix Hosts
    You cannot just run something on top of already created hosts (excpet if it is a external script and you do all mods over API)
    This should be done already during discovery. You need a discovery check, that returns your required info and then you can build discovery actions based on that... like here https://www.zabbix.com/documentation...discovery/rule
    First they have a check that retutrns data, is it linux or windows, then add 2 actions, one for linux one for windows. Same applies to your case... a check that would return a type ( swithc/AP) and then actions attach correct template(s), additional to placing them to correct host group... (conditions with and/or in discovery rules).
    • sbartesaghi
      • Feb 2026
      Thank you for yuor reply
      I already config my zabbix with discovery action based on received value
      Thanks a lot!!
