Hello, I've been trying to connect Ceph from my proxmox cluster into Zabbix Server via Zabbix Agent 2 integration. Unfortunately, I am unable to access my logs.
I am using Zabbix Server version 7.0.23 and Zabbix Agent 2 version 7.4.7.
Here are steps I've taken in order to connect Ceph into my Zabbix Server:
- I added Ceph as host and used Ceph template, provided required macros (API Key, user and connection) as Zabbix documentation stated
- On my Ceph MGR node, I added my Server's IP address into /etc/zabbix/zabbix-agent2.conf
- I enabled restful API and created an API key for Zabbix
After restarting my Agent 2, I ran zabbix_get -s 127.0.0.1 -k ceph.ping["https://localhost:8003","zabbix-monitoring","a4bb2019-XXXX-YYYY-ZZZZ-abcdefghij"] command, which resulted in output 0.
However, my Zabbix Server dashboard says that "The connection to the Ceph RESTful module is broken (if there is any error presented including *AUTH* and the configuration issues).".
I also noticed that I can't run other ceph related gets, such as ceph.status (with same parameters of course). The error I get is:
I tried disabling TLS encryption temporarily for the sake of troubleshooting, but I didn't manage to succeed. I looked around in both Zabbix, Ceph documentations and other forum posts, but the information is scarce. I am happy to provide more necessary details in case I missed something, thank you for help in advance.
ZBX_NOTSUPPORTED: Cannot fetch data: Post "https://zabbix-monitoring:***@localhost:8003/request?wait=1": tls: failed to verify certificate: x509: certificate is not valid for any names, but wanted to match localhost.
