How to pass value with "[" in UserParameter
  • Manuel Deschambault
    • Jan 2026
    • 27
    Running Zabbix 7.4 on AlmaLinux 9.
    Have created a UserParameter that I call from Zabbix that executes a curl command and parses the result, giving me 3 datapoints
    I have created 3 dependent items that extract the data from this master item (to break down the 3 datapoints into 1 per item)
    This works fine, I have already added 3 master items and for each their 3 dependent items.
    Now I have an issue, I have a field I need to pass along the has a [ symbol, and zabbix tells me there is a error in my UserParameter string, "Incorrect syntax near...." to be more precise, and if I simply remove the [ symbol, all is fine. I have tried to include the string in single quotes, double quotes, but none of these seem to pass the data to my bash script.
    I have had field in the above 3 master items that have weird characters, but all of them passed with the string in single quotes, but not the [ character...
  • guntis_liepins
    • Oct 2025
    • 61
    There is setting in zabbix agent cofig UnsafeUserParameters=1 may help.
    May be you shoud use not UserParameters, but HTTPAgent with JSONPath preprocessing https://www.thezabbixbook.com/ch04-z...preprocessing/.
      • Jan 2026
      • 27
      I already did that, had to set this from the get-go to pass custom SQL queries to the agent. When I have one of the many restricted parameters (and they are many, seems whoever created the passwords we need to use had a requirement for symbols being present), I found no way to have Zabbix pass this off to my UserParameter BASH script
      • guntis_liepins
        • Oct 2025
        • 61
        IDK, if your UserParameter is a script, may be youcan pass parameters base64 encoded and decode before use ?
        • kyus
          • Feb 2024
          • 210
          You can pass the hex code for the bracket in your item key and later convert it to the literal bracket in your bash script.
          user.parameter[5B]
          UserParameter=user.parameter[*],/tmp/a.sh "$1"
          cat /tmp/a.sh
          #!/bin/bash
          printf '%b\n' "\\x$1"​
          zabbix_agent2 -t user.parameter[5B]
          user.parameter[5B]                           [s|[]
          • guntis_liepins
            • Oct 2025
            • 61
            base64 basically will do the same , but for all symbols and in relativaly standard way
              • Jan 2026
              • 27
              Thanks, I will look at this option
