I am new to Zabbix and have been configuring a "Global" Map.
As a result I have a lot of Icons that are close to each other.
I have looked at Problem Display and I see 3 options:
All, Seperated and Unacknowledged.
While I want the "All" option the amount of text covers the other icons and it's confusing to look at.
Is there anyway I can instead of displaying "2 problems" or "hostname is unavailable by ICMP", It could "2" for "2 problems" or "hostname" for "hostname is unavailable by ICMP"?
Failing that if their is any way not to display the "2 problems" or "hostname is unavailable by ICMP" text at all it would be good.
This would clean up the map for me and make it legible.
I have the hosts icons set for different colours for "Default, Problem, Maintenance and Disabled"
Any help or alternative solutions would be appreciated.
Cheers
Jay
Cheers
Jay
