Capture X number of lines during log monitoring
  • ben maina
    • Jun 2017
    • 17
    How can i capture X number of lines ones a certain regex is seen? Eg If i want to check the word "ERROR" in a log file i would do this:
    log[/var/log/celery/cbol_register_member.out.log,ERROR].
    All i wanted is that when "ERROR" is detected on that line, zabbix should output the next eg 5 lines after ERROR is seen. How can i achieve this.
    I am using zabbix 3.0. Should i use max lines or how does maxlines work?. Kindly assist
