How do you deal with trend alerts and reports?
  • G0nz0uk
    • Apr 2021
    • 72
    We have about 6k host devices we monitor in Zabbix (7.4.7). There are all sorts of devices we have to monitor. We don't manage these devices, however I have noticed there are some devices that repeatedly lose ICMP or SNMP access and get missed.
    I can see on the graphs that this is happening. I have a simple trigger like this to capture when it happens.
    max(/Diagnostics-boards/zabbix[host,snmp,available],#20)=0
    so after 20mins (1 x 1m polls) we get an alert.
    What metric would you use to trigger if for example a devices has repeatedly had issues over a 30 day period? I'd call this 'Trend' alerts or something.
    What they do is fix the device in question and don't realise its a repeating problem so I'd like to capture this.
    Any ideas would be great.
  • troffasky
    • Jul 2008
    • 639
    I don't have a trigger to handle this kind of scenario ["meta-trigger"] but I do keep an eye on the top 100 triggers report.
    • G0nz0uk
      • Apr 2021
      • 72
      That's a useful report actually. Can these be emailed out?
      I just filtered out using tags to get a view I like. Doesn't look like you can save these custom views?
      • troffasky
        • Jul 2008
        • 639
        The parameters are part of the URL, so once you get it how you like it you can bookmark that URL.
        I've never used emailed reports but it looks like they are just dashboards. So create a dashboard with the "Top Triggers" widget in it, and schedule that.
