MySQL database trigger owners and what not ..
  • ZabbixSeeker
    • Mar 2026
    • 32
    So I have a vague memory of moving a database from one place to another. And things stopped working - some kind of mysql triggers weren't working. The database user Zabbix didn't have access to them, or something.
    Does this ring a bell?
    I'm considering renaming a database, and thus I need to create a new zabbix user probably with right to that database. But there will be database triggers and what not in that database that might break if I create a new zabbix database user or change the name of the database?
    There are traps here, are there not?
  • ZabbixSeeker
    • Mar 2026
    • 32
    What about stored procedures etc etc?
    • ZabbixSeeker
      • Mar 2026
      • 32
      Here's part of the answer. If you run SQL command
      show triggers from zabbix_server;
      then you'll see that a specific user (the one you used to create the database) is the definer of the Zabbix database mysql triggers.
      what this means, is that the database schema is tied to a user that you initialized the database with in the past. Those mysql triggers are part of that user - the definer of these triggers determines the permissions of those triggers.
      So, if you think that you can just add another user, beyond 'zabbix'@'localhost', e.g. 'zabbix'@'%' that can connect from another host - you're screwed.
      What other gotchas are there? Feels like this isn't the end of the story.
      • ZabbixSeeker
        • Mar 2026
        • 32
        How do I Un-foobar this? I wanna get rid of the zabbix_server@10.. user.
        Is it safe to drop all these triggers.. and re-define them with a sane user by using the init script for the version of this database?
        How will these "definer" values affect upgrades?
        mysql> SELECT TRIGGER_SCHEMA, TRIGGER_NAME, DEFINER
        -> FROM information_schema.TRIGGERS;
        | TRIGGER_SCHEMA | TRIGGER_NAME | DEFINER |
        | sys | sys_config_insert_set_user | mysql.sys@localhost |
        | sys | sys_config_update_set_user | mysql.sys@localhost |
        | zabbix_server | connector_insert | [email protected].% |
        | zabbix_server | connector_update | [email protected].% |
        | zabbix_server | connector_delete | [email protected].% |
        | zabbix_server | proxy_group_insert | [email protected].% |
        | zabbix_server | proxy_group_update | [email protected].% |
        | zabbix_server | proxy_group_delete | [email protected].% |
        • ZabbixSeeker
          • Mar 2026
          • 32
          Why thought of the clever idea of using triggers in mysql instead of doing proper transactions - for this application? I bet a billion things have broken because of this.
          Users bound to specific hosts are hardcoded into the triggers, forever, unless you do some kind of surgery on the database.
