Frontend messaging sound playback stops after a minute (Zabbix 3.2)
  • erkin
    • Aug 2017
    Hi. I need zabbix to play alarm sound until someone cuts it off manually or the problem is cleared. When trigger becomes active zabbix shows the "problem" message in top right corner and starts playing alarm sound, and after a minute the sound stops playing. When I refresh the page, it starts playing again, and stops again after a minute. Configuration in User profile > Messaging doesn't help. Maybe I need to change something .conf file? I would appreciate if you help me with this.
