Cisco Catalyst 9300 and 9500 switches template required!!!!
  • Networkmonitor
    • Apr 2026
    We are needed to monitoring Cisco Catalyst 9300 and 9500 switches using Zabbix. While basic SNMP data is being collected, we could not find an official or community-supported template not available so How to monitoring this switches? pls suggest
  • Manuel Deschambault
    • Jan 2026
    • 27
    The documentation on making your own templates and discovery rules are pretty good. I created a template for our PDUs using the Zabbix documentation. I would recommend giving it a go.
    • Networkmonitor
      Networkmonitor commented
      Thanks for the Manuel Deschambault
  • irontmp
    • Sep 2023
    • 99
    Originally posted by Networkmonitor
    We are needed to monitoring Cisco Catalyst 9300 and 9500 switches using Zabbix. While basic SNMP data is being collected, we even reviewed a PowerPoint download on Cisco monitoring strategies, but we could not find an official or community-supported template available. So how to monitor these switches? Please suggest.
    Since no official Zabbix template exists for Cisco Catalyst 9300/9500, you can monitor them by using generic Cisco SNMP templates and adding custom OIDs from Cisco MIBs for CPU, memory, interfaces, fans, and power supplies. You can also use interface auto-discovery or leverage REST API/NETCONF for advanced telemetry.
    • Networkmonitor
      • Apr 2026
      Thank for input irontmp
