first configuration to zabbix
  • orb100
    • Aug 2017
    I write here topics in the trash I want to define there and I did not understand through YouTube, tell me if there are things you already know and you can help me:
    On the servers: RAM, cpu includes their exploitation by deploying with the option of notifications.
    Of course disks (free space and volume used out of total). If there is also good disk integrity what is good.
    Network - if the network cards are "up", traffic in real time and total (say monthly, etc.).
    Monitoring utilization of CPU and RAM by deployments.
    Monitoring the availability of processes and services (including services not of windows).
    Monitoring of dhcp and dns.
  • allexpetrov
    • May 2017
    • 361
    Hi, orb100 !
    In Zabbix you options how to get those values, please check the manual :
    And you can use Basic Templates for the first run (For Windows,Linux, SNMP monitored hosts) and then you can create your own templates with the things you want to have.
    If you want to receive notifications, please go through the triggers manual:
    https://www.zabbix.com/documentation...onfig/triggers and actions manual:
    Also you can check this link and they will setup everything for you: https://www.zabbix.com/services
