3.2 vmWare monitoring problem
  • vlam
    • Jun 2009
    • 166
    Hi
    Clean install of Zabbix 3.2 with the build in templates I get the following when using the build in vmWare monitoring
    noname.xml:127: parser error : StartTag: invalid element name
    <!% if (!debugBuild) {
    noname.xml:130: parser error : StartTag: invalid element name
    <!%script type="text/javascript" src="assets/csd_api_all.js"%><!/script%>
    noname.xml:131: parser error : StartTag: invalid element name
    <!% } else { %>
    noname.xml:144: parser error : StartTag: invalid element name
    noname.xml:240: parser error : CData section not finished
    swfobject.embedSWF(
    'UI.swf'
    noname.xml:240: parser error : Premature end of data in tag script line 160
    noname.xml:240: parser error : Premature end of data in tag body line 42
    noname.xml:240: parser error : Premature end of data in tag html line 4
    <!% } else { %>
    swfobject.embedSWF(
    'UI.swf'
    <!% } else { %>
    swfobject.embedSWF(
    'UI.swf'
    <!% } else { %>
    swfobject.embedSWF(
    'UI.swf'
    <!% } else { %>
    swfobject.embedSWF(
    'UI.swf'
    <!% } else { %>
    swfobject.embedSWF(
    'UI.swf'
    Is there anything that anyone can suggest I need to solve this?
    4 Zabbix Frontend Servers (Load balanced)
    2 Zabbix App Servers (HA)
    2 Zabbix Database Servers (HA)
    18 Zabbix Proxy Servers (HA)
    3897 Deployed Zabbix Agents
    6161 Values per second
    X-Layer Integration
    Jaspersoft report Servers (HA)
