NetBotz 550 Template Help
  • daven1985
    • Aug 2017
    • 12
    Morning,
    I would love it if someone has a Template or the know-how to create a template for a APZ NetBotz 550.
    When I tried to create one it just keeps failing.
    Thanks.
  • allexpetrov
    • May 2017
    • 361
    Hi, daven1985 ,
    I belive that you want to monitor your NteBotz using SNMP, yes? Then you need to find the SNMP MIBs and, using them, create the template or try to google/search zabbix for something similar https://share.zabbix.com/search?sear...z&search_cat=1
    Regards,
    Alex
