Cisco Catalyst 9200
  • ALX7777
    • Apr 2026
    Cisco Catalyst 9200
    Hello everyone,
    I’m new here and have a question.
    Recently, we replaced some switches in our company. Since the replacement, I’m no longer able to reach the switches. The model is Cisco Catalyst 9200L-48P-4X.
    Could this be related to templates or macros? In Zabbix, I couldn’t find any suitable templates for the Catalyst 9200.
    We also have some Cisco Catalyst 9300 switches, which I can monitor without any issues using the “Cisco IOS by SNMP” template. Unfortunately, this doesn’t seem to work for the 9200 series.
    Does anyone have experience with this or can recommend a solution?
    Thanks in advance,
    ALX7777
  • troffasky
    • Jul 2008
    • 639
    Check SNMP configuration.
    All Cisco switches will monitor the same way with SNMP, if it works with a 93xx it will work for 92xx.
    • ALX7777
      • Apr 2026
      Danke.
      Meinst du SNMP-Konfiguration direkt an dem Switch?? Gute Idee, stimmt!!! Werde ich schauen. Danke
      • ALX7777
        • Apr 2026
        Es hat mit SNMP Konfiguration am Switch geklappt. Ich kann jetzt die Switches erreichen
        Danke
