Cannot see data CPU and etc except zabbix in Monitoring-->Host
  • kronicklez
    • Mar 2025
    • 54
    Hi all,
    Can some help me how to make the other info can display such as CPU and memory utilization under "Monitoring--> Host". If i click graph it can display the CPU and memory utilization. It just cannot display under "Monitoring --> Host". But on zabbix server itself can see the info in the "Monitoring --> Host". Below snapshot is the issue. I'm using zabbix 7.4.9. Appreciate any help.
  • hrrapozo
    • Nov 2025
    • 33
    As a suggestion you could create a dashboard and use the Top Host widget to display the values you want.
    Here is a sample:
    And what it generates
    Notes:
    The host name of zabbix2 has its zabbix agent turned off and the host name of hrrtest is off the network. The host name of zabbix7d is what the Zabbix server is on.
    Hope this helps.
    • kronicklez
      • Mar 2025
      • 54
      Do u means the zabbix not support automatically display info for other equipment except zabbix itself only in section "Monotoring --> Host" ?
      • hrrapozo
        • Nov 2025
        • 33
        Currently I am running Zabbix 7.0.25 and this is what I see if I do a Monitoring > Hosts on the host group Zabbix servers. I tried another host group that has a different template but neither of them display shows columns like CPU Util %, CPU Cores, Memory Util %, Memory Available, Memory Total and Disk Used %.
