zabbix 3.4.0 - unsupported value (0)
  • mvrk
    • Oct 2008
    • 71
    I have script that is currently returning 0 for a certain item, and it was working with zabbix agent 3.0.9, but now with 3.4.0 i get unsupported:
    zabbix_agentd -t "syslog.errors[scsi 2]"
    syslog.errors[scsi 2] zabbix_agentd [87101]: Warning: 0
    [m|ZBX_NOTSUPPORTED] [0]
    The item configured on zabbix is Numeric (unsigned)
    Any ideas?
  • vso
    Zabbix developer
    • Aug 2016
    • 190
    Any ideas?
    Could try increasing log level and looking into Zabbix log on agent, what does it say?
    • mvrk
      • Oct 2008
      • 71
      I configured log level 5, but nothing much appears:
      on server:
      89436:20170822:190137.023 Item [DB1:syslog.errors[e1000 eth1]] error: 0
      89449:20170822:190137.023 End of preprocessor_get_queued_item()
      89436:20170822:190137.023 End of get_value():NOTSUPPORTED
      on agent:
      103656:20170822:185526.964 Requested [syslog.errors[e1000 eth1]]
      103656:20170822:185526.964 In zbx_popen() command:'/var/lib/zabbix/syslog.sh e1000 eth1 '
      103656:20170822:185526.964 End of zbx_popen():6
      104497:20170822:185526.964 zbx_popen(): executing script
      103656:20170822:185526.969 In zbx_waitpid()
      103656:20170822:185526.969 zbx_waitpid() exited, status:1
      103656:20170822:185526.969 End of zbx_waitpid():104497
      103656:20170822:185526.969 0
      103656:20170822:185526.969 Sending back [ZBX_NOTSUPPORTED: 0
      • vso
        Zabbix developer
        • Aug 2016
        • 190
        on server:
        on agent:
        What if you replace you script contents to printf 0
        Does it work then ?
        • mvrk
          • Oct 2008
          • 71
          Its a bash script.
          returns values using echo
          ex: echo "0"
          • vso
            Zabbix developer
            • Aug 2016
            • 190
            Its a bash script.
            ex: echo "0"
            what if you replace to printf "0" ?
            • mvrk
              • Oct 2008
              • 71
              Already did, same error.
              • sles
                • Oct 2005
                • 80
                We have the same problem here
                I created issue https://support.zabbix.com/browse/ZBX-12594
                • sles
                  • Oct 2005
                  • 80
                  OK, they say this is not bug, this is feature,
                  now they check if errorlevel is not 0 and if not- then script failed.
                  this means grep or find are usually failed and almost all scripts have to be rewritten by at least edding exit 0 ..
                  this is crazy...
