Housekeeping question
  • G0nz0uk
    • Apr 2021
    • 72
    I've set my house keeping to 14 days. Does this overwrite everything? I have a template I want to keep at 31 days which I I have manually set. I assume I should untick the 'Override item history' now after doing that?
    Apologies I can't seem to reduce the size.
    Click image for larger version  Name:	image.png Views:	0 Size:	202.6 KB ID:	513231
    • 5002
    Yes.this will override any values you have set in item itseltf... And I think also those which are shorter than 14d..
    • G0nz0uk
      • Apr 2021
      • 72
      Ah I see so is it best to turn override item history and set them manually? I really only want to keep 14 days of history but I have one template where I need to keep 31 days.
        • 5002
        It does not have exceptions... so you need to diable it if you need different timeframes. Bad thing is, that new item creation suggest by default 31 days and I am sure noone remembers to set it to 14.. I think it is not somewhere in settings..
