Resetting a trigger from a different snmp trap
  • Muadeeb
    • Aug 2017
    Probably a pretty basic thing to do, but my Google-fu is failing me. I have a device monitored via SNMP which sends a trap (which I am receiving in Zabbix) on a link failure, and a different trap on link restoration. I want the trigger to alert on link failure, and then clear on link up. I tried using
    {Dragonwave Template:snmptrap["IF-MIB::linkDown"].regexp(IF-MIB::linkUp)}=0 or {Dragonwave Template:snmptrap["IF-MIB::linkDown"].regexp(IF-MIB::linkDown)}=1
    But that doesn't appear to work.
    I'm using v3.0.10 with the python handler to deal with the traps. And, yes, the names are resolving to OIDs.
  • Muadeeb
    • Aug 2017
    Figured out how to do it by looking at the hysteresis examples.
    ({Dragonwave Template:snmptrap["IF-MIB::linkDown"].regexp(.*)}=1 and
    {TRIGGER.VALUE}=0)
    or
    ({Dragonwave Template:snmptrap["IF-MIB::linkUp"].regexp(.*)}=0 and
    {TRIGGER.VALUE}=1)
    Thanks for the help!
