Zabbix audit shows reverse proxy IP-address!
  • ZabbixSeeker
    • Mar 2026
    • 25
    Failed logins etc, in the audit, all logs the reverse proxy IP address.
    I am using zabbix web docker.
    I've only seen multiple bug reports and unsupported unstable hacks. Is there an officially supported way to log the correct IP address?
    My reverse proxy provides the real IP address via headers "X-Forwarded-For" and "X-Real-Ip".
  • Answer selected by ZabbixSeeker at 05-05-2026, 23:58.
    ZabbixSeeker
    • Mar 2026
    • 25
    Okay, so I reverse engineered the whole shebang.
    .. unsupported yet documented. Supported since X version though.
    There you have it. GL whoever's reading this forum post as documentation.
    • ZabbixSeeker
      • Mar 2026
      • 25
      Got a hint.
      These ENV-vars can be used.
      WEB_REAL_IP_FROM=
      WEB_REAL_IP_HEADER=
      • ZabbixSeeker
        • Mar 2026
        • 25
        Nope. Horrific documentation, sorry.
        setting WEB_REAL_IP_FROM to 0.0.0.0/0 or the actual source ip (of the proxy) and setting WEB_REAL_IP_HEADER to the exact header providing the real ip, does nothing.
        I am TCP-dumping the traffic and zabbix ignores it all. I am rebuilding the image and everything.
        • ZabbixSeeker
          • Mar 2026
          • 25
          docker inspect and tcp dumping the traffic.. everything is set up right, and I've tried all kinds of variations of setups that should work ..
          • ZabbixSeeker
            • Mar 2026
            • 25
