Too many long running queries in Zabbix PG "SELECT h.* FROM history..."
  • g8a
    • May 2026
    Hello!
    I'm experiencing a lot of long running queries on our zabbix postgresql, and they come from Grafana dashboards (it's the main assumption - actually the DB overload could be caused by Grafana Direct DB Connection bypassing the API and querying history tables directly. Reducing pm.max_children helps with RAM but does not stop the DB flood)
    seconds_running | table_name | application_name | query_preview
    57249 | history_uint | | SELECT h.* FROM history_uint h WHERE h.itemid IN (XXXX)
    57249 | history | | SELECT h.* FROM history h WHERE h.itemid IN (XXXX)
    Tables affected are "history_uint" and "history" as you can see, and this is affecting our environment because Grafana dashboards never load information.
    psql (PostgreSQL) 13.23
    zabbix_server (Zabbix) 7.0.21
    We have tried restarting, scaling the server ram, upgrading the pm.max_children from 50 to 180...
    All of these still not affecting and queries will still take too much to run.
    Any ideas how to troubleshoot this? this happens since last Azure maintenance (last weekend, they restarted the zabbix db)
    Thanks in advance.
  • guntis_liepins
    • Oct 2025
    • 61
    This query is insane - it is not limited in time and size. Something seriously bad and wrong is done with Grafana dashboard.
    These queries mean that grafana dashboard for some reason reads ALL history for included items...
    You must fix queries for Grafana dashboard.
    There are some other options like partitioning , TimescaleDB and reducing size of history tables, but with queries which go multiple times over all history tables - it will not help.
    • g8a
      • May 2026
      Thanks for your answer.
      The problem is we are using zabbix data source, and not the db one, so we can't customize the db query.
      • ZabbixSeeker
        • Mar 2026
        • 34
        There's an official grafana-plugin and/or grafana-zabbix-integration somewhere. Use that instead of manual SQL queries.
          • 5002
          I have just exact same case ..
          Some API calls (what this grafana zabbix plugin is also using) manage to run for hours... Which in the end creates locks in DB, which affects other things like compression jobs for timescale etc...
          In my case I was able to trace it to some specific script items and I killed those, I will see tomorrow how the db behaves...
          that query itself is not even a huge one..: API call for it is just as example of history.get from docs...
          "jsonrpc": "2.0",
          "method": "history.get",
          "params": {
          "output": "extend",
          "history": 0,
          "itemids": "23296",
          "sortfield": "clock",
          "sortorder": "DESC",
          "limit": 10
          "id": 1
          we just had a bit more items (23) in list and limit is also 23... basically finding last values for 23 items...
          this is the resulting query...
          SELECT h.* FROM history_uint h WHERE h.itemid IN (26342018,26389356,26389725,26395776,26397646,2640 0455,26401893,26409391,26412250,26414105,26414294, 26420466,26423043,26425512,26427469,26429200,26431 452,26432650,26434521,26437200,26440663,26443329,2 6445753) AND h.clock>=1777442456 ORDER BY h.clock DESC LIMIT 23
          But, if you are not using time_from and time_till parameters here, then obviously it will do full scan of hisotry for thse values... that "clock" value is taken as 14 days ago, which is as long as we keep history...
          And in some reason this query manages to run hours... funny enough, there is actually no values in history, as this specific monitoring has been broken for a while, items are all "not supported", as master item fails...
          Same happens if compression is used or not used in DB. Without compression effects of those queries locking are not so big...
          zabbix version has been 7.0.22-25... I managed to relocate my db during this time from PG 14 to PG 16 ... the webserver changed from apache to nginx... no difference in behaviour...
          So as far as I can tell, it is not exactly grafana plugin problem, but API call issue..
          g8a whats the query you used to display those longrunning queries?
          Exactly what OP is doing... Said it just in last post "The problem is we are using zabbix data source, and not the db one, so we can't customize the db query."
          • g8a
            • May 2026
            "jsonrpc": "2.0",
            "params": {
            "output": "extend",
            "history": 0,
            "itemids": "23296",
            "limit": 10
            "id": 1
            Hello! thanks for sharing.
            To see the long running queries I queried the 'pg_stat_activity' table.
            To give more information:
            The dashboard from Grafana (Problems panel) seems to query the whole History table (almost 1m~ rows) and as it's using the zabbix-grafana plugin, has not many customizations to improve.
            What we could see is that the behavior of the dashboard is weird because some fields can limit the query and others not. 'Group' for example doens't limit it, even if you add a zabbix host group of 6 servers, it will still give a timeout or server denying the api request, if you instead of this, put a Host filter, it seems to limit the query.
            In any case, a solution I've found for this is to stop using the zabbix plugin and use the Postgresql plugin, a manually written query is the best way to limit and make it work, but it's just a workaround, not a final solution as we want to still use the zabbix plugin in Grafana.
              • 5002
              You did not mention it, but what type of frontend you have there? apache or nginx?
              • g8a
                • May 2026
                Apache for Zabbix and Nginx for Grafana.
                Another theory is these long running queries could be done by some housekeeping/zabbix syncs due to the azure maintenance db restart, because we did not have this issue before.
                  • 5002
                  I created a support ticket, they identified the bug,which report is now available at https://support.zabbix.com/browse/ZBX-27803
