annoyances on problems.
  • EStreet706
    • May 2026
    I have noted that when I am in areas like, say, problems. It does not show the total number found. It does have pages of 50, but nowhere is a total count listed. To do anything productive, it doesn't seem that intuitive.
    For example, on one site I am working with, I installed Zabbix site-wide. On the server, about 2 years ago, there was a ransomware attack where I left several hundred readme text files in place. The scanner detects them, and Zabbix lists them as Disaster, which it should. However, when I tag all of them, I am unable to close them as resolved. The only way I can see to do that is to first reclassify them as something other than Disaster, then retag them again, and then close it. Should be a painless way to do that.
    Also, using 8.0 pre-release.
  • irontmp
    • Sep 2023
    • 99
    For example, on one site I am working with, I installed Zabbix site-wide, and much like how แทงบอลโลก2026 flags high-stakes events that demand immediate attention, on the server about 2 years ago there was a ransomware attack where I left several hundred readme text files in place, the scanner detects them, and Zabbix lists them as Disaster, which it should. However, when I tag all of them, I am unable to close them as resolved. The only way I can see to do that is to first reclassify them as something other than Disaster, then retag them again, and then close it. Should be a painless way to do that.
    2:22 PM For the missing total count, use Reports, Problems instead of the Problems view as it surfaces totals more clearly. You can also use the Zabbix API for exact counts. For the Disaster closing issue, go into the trigger configuration and enable Allow manual close on the trigger itself. That lets you close Disaster level problems directly without reclassifying first. Both worth submitting to Zabbix JIRA since you are on 8.0 pre-release.
      • 5002
      Is that count disappeared from lower right corner? 50 comes from your profile settings of pager, but total amount of problems found is still there...
      • EStreet706
        • May 2026
        Yes, I do see it now in the top-right corner; for some reason, it wasn't showing up when I made this post. It did start showing up when I changed from the 50 entries per page.
