Upgrade issue help
  • vedranOP
    • Sep 2015
    • 12
    Upgrade issue help
    Hello!
    Please help, I upgraded from 3.2 to 3.4 but now i have a following error:
    Database error
    The frontend does not match Zabbix database. Current database version (mandatory/optional): 3020000/3020000. Required mandatory version: 3040000. Contact your system administrator.
    Can someone guide me how to fix it? How to upgrade database?
    I am not a linux user, more of a basic user...
    Bg,
    V
  • LenR
    • Sep 2009
    • 1011
    You need to start your server first. It will upgrade the database, then your frontend will be happy.
    From server log:
    21295:20170823:230709.776 using configuration file: /etc/zabbix/zabbix_server.conf
    121295:20170823:230709.849 current database version (mandatory/optional): 03000000/03000000
    121295:20170823:230709.849 required mandatory version: 03040000
    121295:20170823:230709.849 starting automatic database upgrade
    121295:20170823:230710.094 completed 0% of database upgrade
    121295:20170823:230712.423 completed 1% of database upgrade
    121295:20170823:230735.434 slow query: 23.011263 sec, "alter table history_text drop column id"
    121295:20170823:230744.823 slow query: 9.387150 sec, "alter table triggers add recovery_mode integer default '0' not null"
    121295:20170823:230752.731 slow query: 7.906211 sec, "alter table triggers add recovery_expression varchar(2048) default '' not null"
    121295:20170823:230752.733 completed 2% of database upgrade
    121295:20170823:230752.779 completed 3% of database upgrade
    121295:20170824:000107.106 completed 99% of database upgrade
    121295:20170824:000107.113 completed 100% of database upgrade
    121295:20170824:000107.113 database upgrade fully completed
    • vedranOP
      • Sep 2015
      • 12
      Hi, thank you for your answer but when I run service zabbix-server status
      Output is:
      zabbix-server.service - Zabbix Server
      Loaded: loaded (/lib/systemd/system/zabbix-server.service; enabled; vendor preset: enabled)
      Active: active (running) since Mon 2017-08-28 21:23:24 CEST; 10h ago
      Any other suggestion or any input what did I do wrong in this step?
      Cheers
      • vedranOP
        • Sep 2015
        • 12
        Had to change the pass in conf file because it was access denied in server log.
        • allexpetrov
          • May 2017
          • 361
          Try to check if the variables in zabbix.conf.php ( /etc/zabbix/web/ ) are correct. I had zabbix/zabbix , but my dbname and dbuser aren't like default.
          Regards,
          Alex!
